基于DC2416A直流到直流单输出电源的参考设计
消耗积分:2 | 格式:pdf | 大小:406.56KB | 2021-07-27
分享资料个
说明
  • DC2416A, Demonstration Circuit features the LTM8003, 40V, 3.5A step-down regulator. This demo circuit is configured to deliver a 5V output from an input voltage between 6V to 40V at a switching frequency of 2MHz. The wide input range of the LTM8003 allows a variety of input sources such as automotive batteries and industrial supplies. Under light load conditions, the available Burst Mode operation supports high efficiency with low output ripple
主要特色
  • Conversion Type
    DC to DC
  • Input Voltage
    6 to 40 V
  • Output Voltage
    5 V
  • Output Current
    3.5 A
  • Efficiency
    91.6 %
  • Topology
    Buck
评论(1)
发评论
jf_80916157 2024-08-06
0 回复 举报
下来用用 收起回复
下载排行榜
全部1条评论
