MAX477 pdf datasheet (300MHz H
消耗积分:10 | 格式:rar | 大小:333 | 2009-02-23
5762
分享资料个
The MAX477 is a ±5V wide-bandwidth, fast-settling,
unity-gain-stable op amp featuring low noise, low differential
gain and phase errors, high slew rate, high precision,
and high output current. The MAX477’s architecture
uses a standard voltage-feedback topology that
can be configured into any desired gain setting, as with
other general-purpose op amps.
Unlike high-speed amplifiers using current-mode feedback
architectures, the MAX477 has a unique input
stage that combines the benefits of the voltage-feedback
design (flexibility in choice of feedback resistor,
two high-impedance inputs) with those of the currentfeedback
design (high slew rate and full-power bandwidth).
It also has the precision of voltage-feedback
amplifiers, characterized by low input-offset voltage
and bias current, low noise, and high common-mode
and power-supply rejection.
The MAX477 is ideally suited for driving 50Ω or 75Ω
loads and is available in 8-pin DIP, SO, space-saving
μMAX, and 5-pin SOT23 packages.
Applications
Broadcast and High-Definition TV Systems
Video Switching and Routing
Communications
Medical Imaging
Precision DAC/ADC Buffer
评论(0)
发评论
下载排行榜
