传统PSTN与VOIP的比较研究
消耗积分:10 | 格式:rar | 大小:233 | 2009-03-02
久醉不醒
分享资料个
从电信级应用的角度出发,对公众电话网和语音IP电话进行了比较研究,其重点包括交换方式、信令、寻址、路由四个方面。通过分析比较,可直观地看出IP电话在交换技术、带宽占用、系统开放性、通信成本、系统灵活性等诸方面优于传统的公众电话网;对IP电话与公众电话网资费比较,阐述了IP电话价格的竞争力,并给出了用户、IP电话营运商、IP电话技术等几个要素循环互动的模型。结果表明,IP电话将成为长途通信的主流应用,公众电话网与IP电话将逐步走向融合。
关 键 词 IP电话; 公众电话网; 比较; 资费
Abstract From the angle of applications given by public telecom enterprises (China Telecom, China Unicom, etc.), the comparative research between traditional PSTN and VOIP has been done in this paper. The switching technology, signal system, protocols as well aw routines were compared and analyzed. The results show that VOIP were much better than PSTN in switching technology. Costing, band consuming, openness and flexibility. Based on the latest official Telecom costing files, the costing comparative results was given out between VOIP and PSTN. The interactive effecting model was given out in this paper. The opinion that VOIP and PSTN should be treated as a whole system was also pointed out.
Key words IP phone; public service telecommunication network; comparative; costing
评论(0)
发评论
下载排行榜
