Stampede 是基于 CoreOS 的混合 IaaS/Docker 编配平台。Stampede 需要一个空的 CoreOS 集群,通过简单的配置就可以拥有可以同时运虚拟机和 Docker 的平台。Stampede 能很好的支持 IaaS 到 Docker 的复杂业务流程,增强了网络,存储和管理方面的能力。Stampede 的最终目标是继续支持传统的 IaaS,同时增强对 Docker 和容器的支持。
安装
通过 Fleet 和 Etcd 配置开始空白的 CoreOS 集群
wget http://stampede.io/latest/cattle-stampede.service fleetctl start cattle-stampede.service
fleetctl list-units
输出
UNIT DSTATE TMACHINE STATE MACHINE ACTIVE cattle-libvirt.7ffe1d-b2c083.service launched b2c0835f.../10.42.1.115 launched b2c0835f.../10.42.1.115 active cattle-stampede-agent.76bcfb-b2c083.service launched b2c0835f.../10.42.1.115 launched b2c0835f.../10.42.1.115 active cattle-stampede-server.01c222-b2c083.service launched b2c0835f.../10.42.1.115 launched b2c0835f.../10.42.1.115 active cattle-stampede.service launched b2c0835f.../10.42.1.115 launched b2c0835f.../10.42.1.115 active
API/UI 已经提供在服务器的 9080。
UI
函数
Virtual Machines
Libvirt/KVM
EC2/OpenStack images work out of the box
EC2 style meta data
OpenStack config drive
Managed DNS/DHCP
User data
Floating IPs
Private networking
VNC Console
CoreOS, Ubuntu, Fedora, and Cirros templates preconfigured
Docker
Link containers across servers
Dynamically reassign links and ports
Networking
VMs and containers can share the same network space
By default, a private IPSec VPN is created that spans servers
All containers and VMs live on a virtual network that can span across cloud
Can also use any libvirt networking models for VMs
Interface
Use web browser to explore and use API
UI
REST API
Command line client
Python API bindings
