Type AV1479 Frequency 2,4…2,5 GHz Bandwidth 0,1 GHz Impedance 50 W DC grounded VSWR 1,5 max Polarisation Vertical Gain 0 dBi E-plane 3 dB beamwidth 80° H-plane 3 dB beamwidth 360° Electrical downtilt None Front to back ratio - Max. Continuous power 0,5 kW RF-connector N or TNC female Operational windspeed 40 m/s (default) Survival windspeed 55 m/s (default) Wind area 0,001 m² Dimensions (HxWxD) 45x94x94 mm Weight 0,2 kg Mounting diameter Æ 30…115 mm pipe Materials Aluminium baseplate Glassfiber radome Copper radiator
