ICT测试系统软件
消耗积分:10 | 格式:exe | 大小:未知 | 2011-02-13
分享资料个
这是一个基于ICT的DOS下的软件,具体情况没有测试过,只是在系统下运行过,可以打开,没有用过ICT系统,所以对这方面不是太了解,哪位朋友需要的,可以测试一下.
Welcome to the PLACE (tm) Development Software from ICT!
PLACE (PEEL Logic Architectural Compiler and Editor) is an advanceddevelopment software product for ICT's family of PEEL (Programmable Electrically Erasable Logic) Arrays and Devices.
PLACE features include:
(1) an architectural editor,
(2) a logic compiler with logic reduction and minimization,
(3) a waveform display logic editor and simulator,
(4) a documentation operation, and
(5) a programmer interface.
The PLACE On-Line Help facility allows quick references for all functions and operations. Press the key for the general Help instructions. If you are not already familiar with the features of the PEEL Arrays and Devices, please refer to the ICT Data Book
例子:
                           8-bit Bidirecional I/O Port.
BI_PORT           PA7024   8-bit Bidirecional I/O Port (part of DEMO1A.PSF).
COUNTER1          PA7024   8-bit Down Counter with Preset, Reset and Hold
GATES1            PA7024   Basic Gates (part of DEMO1A.PSF).
REG1              PA7024   Basic Registers, 8-bit Down Counter, 2-bit State
                           Machine and 4-bit Shift Register (all are part of
                           the DEMO1A.PSF)
TIMER             PA7024   16-Bit Programmable Clock Generator/Interrupt Timer
JACK7024          PA7024   Blackjack Machine Example
TC7140            PA7140   Programmable Clock Generator and Timer/Interrupt
                           Counter
ST7128            PA7128   8-bit Loadable Counter and 4-bit State Machine
| PEEL Devices |
V8GATES           18CV8    Basic Logic Gates.
V8REGS            18CV8    Basic Registers and Latches.
V8CLKADD          18CV8    Clock Divider Address Decoder.
V8BUSMUX          18CV8    Bus Programmable 8 to 1 Multiplexer.
V8FCNTR           18CV8    8-bit Counter with Function Controls.
V8CPORT           18CV8    Change-of-State Input Port with Interrupt.
V8SYNC            18CV8    Synchronization Circuits.
V10CNT8           22CV10   8-bit Up/Down Loadable Counter with Carry-out or
                           Borrow-in.
PARV10A           22CV10A  9-bit Even/Odd Parity Generator/Checker.
V10ZPORT          22CV10Z  Change-of-State Input Port with Interrupt.
*** PLACE Template files ***
File Name (.PSF)     Device
ANEW7024             PA7024
ANEW7140             PA7140
ANEWV8               18CV8
ANEWG10              20CG10
ANEWG10A             20CG10A
ANEWV10              22CV10
ANEWV10A             22CV10A
ANEWV10P             22CV10A+
ANEWV10Z             22CV10Z
评论(0)
发评论
下载排行榜
