分频电路设计和仿真
1、偶数分频
  • 方法
直接使用计数器实现,在计数一半时将时钟翻转即可;
  • 4 分频示例
1module clk_div_even
 2#(
 3    parameter DIV = 4
 4)
 5(
 6    input clk,
 7    input rstn,
 8    output reg clko
 9);
10
11reg [DIV/2-1:0] cnt;
12
13always @(posedge clk or negedge rstn)
14begin
15  if(!rstn) begin
16    cnt <= 0;
17    clko <= 0;
18  end else begin
19    if(cnt == (DIV/2 - 1)) begin
20      clko <= ~clko;
21      cnt <= 0;
22    end else begin
23      cnt <= cnt + 1;
24    end
25  end
26end
27
28endmodule
  • 仿真波形:
分频电路
2、奇数分频
  • 非 50% 占空比
使用计数器,当计数到一半时候进行翻转时钟,当计数到分频值时候再次翻转;
1module clk_div_odd1
 2#(
 3    parameter DIV = 5
 4)
 5(
 6    input clk,
 7    input rstn,
 8    output reg clko
 9);
10
11reg [DIV-1:0] cnt;
12
14begin
15  if(!rstn) begin
16    cnt <= 0;
17  end else begin
18    if(cnt == (DIV-1)) begin
19      cnt <= 0;
20    end
21    else begin
22      cnt <= cnt + 1;
23    end
24  end
25end
26
27always @(posedge clk or negedge rstn)
28begin
29    if(!rstn) begin
30      clko <= 1'b0;
31    end else begin
32      if(cnt == (DIV-1)/2) begin
33        clko <= ~clko;
34      end
35      else if(cnt == (DIV -1)) begin
36        clko <= ~clko;
37      end
38      else begin
39        clko <= clko;
40      end
41    end
42end
43
44endmodule
仿真波形:
分频电路
  • 50% 占空比
上升沿和下降沿分别做分频,将结果进行或操作即可;
1module clk_div_odd2
 2#(
 3    parameter DIV = 5
 4)
 5(
 6    input clk,
 7    input rstn,
 8    output clko
 9);
10
11//posedge clk
12reg [DIV-1:0] pos_cnt;
13reg pos_clk;
14
15always @(posedge clk or negedge rstn)
16begin
17  if(!rstn) begin
18    pos_cnt <= 0;
19  end else begin
20    if(pos_cnt == (DIV-1)) begin
21      pos_cnt <= 0;
22    end else begin
23      pos_cnt <= pos_cnt + 1;
24    end
25  end
26end
27
28always @(posedge clk or negedge rstn)
29begin
30  if(!rstn) begin
31    pos_clk <= 0;
32  end else begin
33    if(pos_cnt == (DIV-1)/2) begin
34      pos_clk <= ~pos_clk;
35    end
36    else if(pos_cnt == (DIV-1)) begin
37      pos_clk <= ~pos_clk;
38    end
39    else begin
40      pos_clk <= pos_clk;
41    end
42  end
43end
44
45//negedge clk
46reg [DIV-1:0] neg_cnt;
47reg neg_clk;
48
49always @(negedge clk or negedge rstn)
50begin
51  if(!rstn) begin
52    neg_cnt <= 0;
53  end else begin
54    if(neg_cnt == (DIV-1)) begin
55      neg_cnt <= 0;
56    end else begin
57      neg_cnt <= neg_cnt + 1;
58    end
59  end
60end
61
62always @(negedge clk or negedge rstn)
63begin
64  if(!rstn) begin
65    neg_clk <= 0;
66  end else begin
67    if(neg_cnt == (DIV-1)/2) begin
68      neg_clk <= ~neg_clk;
69    end
70    else if(neg_cnt == (DIV-1)) begin
71      neg_clk <= ~neg_clk;
72    end
73    else begin
74      neg_clk <= neg_clk;
75    end
76  end
77end
78
79//clk output
80assign clko = pos_clk | neg_clk;
81
82endmodule
仿真波形:
分频电路
3、小数分频
以设计2.6分频为例;
  • 方法:
(1)将小数取分数形式,即 2.6 = 13/5;
(2)因为2.6在2~3之间,因此可以使用2分频和3分频组合实现;
(3)由如下方程进行设计:
1x + y = 5
22x + 3y = 13
求得 x = 2, y = 3 , 即使用2个2分频和3个3分频时钟实现2.6分频;
(4)设计总计数器,范围为 013 计数,那么在 04范围内进行2分频的计数,在5~13范围内进行3分频的计数,然后根据计数生成需要的时钟;
(5)
  • Verilog实现:
1//clk divider: 2.5 , M/N = 13/5
 2module clk_div_mn
 3#(
 4    parameter M = 13,
 5    parameter N = 5
 6)
 7(
 8    input clk,
 9    input rstn,
10    output reg clko
11);
12
13parameter DIV_M = 2;
14parameter DIV_N = 3;
15
16reg [3:0] cnt;
17always @(posedge clk or negedge rstn)
18begin
19  if(!rstn) begin
20    cnt <= 0;
21  end else begin
22    if(cnt == (M-1)) begin
23      cnt <= 0;
24    end else begin
25      cnt <= cnt + 1;
26    end
27  end
28end
29
30reg [3:0] cnt2;
31reg [3:0] cnt3;
32
33parameter CHANGE = 4;
34
35always @(posedge clk or negedge rstn)
36begin
37  if(!rstn) begin
38    cnt2 <= 0;
39    cnt3 <= 0;
40  end else begin
41    if(cnt <= (CHANGE-1)) begin
42      cnt3 <= 0;
43      if(cnt2 == (DIV_M-1)) begin
44        cnt2 <= 0;
45      end else begin
46        cnt2 <= cnt2 + 1;
47      end
48    end
49    else if(cnt > (CHANGE -1)) begin
50      cnt2 <= 0;
51      if(cnt3 == (DIV_N -1)) begin
52        cnt3 <= 0;
53      end else begin
54        cnt3 <= cnt3 + 1;
55      end
56    end
57  end
58end
59
60always @(posedge clk or negedge rstn)
61begin
62  if(!rstn) begin
63    clko <= 0;
64  end else begin
65    if(cnt < CHANGE) begin
66      if(cnt2 == 0 || cnt2 == DIV_M/2) begin
67        clko <= ~clko;
68      end
69      else begin
70        clko <= clko;
71      end
72    end
73    else begin
74      if(cnt3 == 0 || cnt3 == (DIV_N-1)/2) begin
75        clko <= ~clko;
76      end
77      else begin
78        clko <= clko;
79      end
80    end
81  end
82end
83
84endmodule
  • 仿真波形:
分频电路
