如何ChatGPT中构建Python解释器
消耗积分:0 | 格式:pdf | 大小:0.13 MB | 2023-02-13
385288
分享资料个
  这个故事的灵感来自于一个类似的故事,在 ChatGPT中构建虚拟机。我印象深刻并决定尝试类似的东西,但这次不是 Linux命令行工具,而是让 ChatGPT成为我们的 Python解释器。
  这是初始化 ChatGPT的初始命令: I want you to act as a Python interpreter. I will type commands and you will reply with what the python output should show. I want you to only reply with the terminal output inside one unique code block, and nothing else. Do no write explanations, output only what python outputs. Do not type commands unless I instruct you to do so. When I need to tell you something in English I will do so by putting text inside curly brackets like this: {example text}。 My first command is a=1.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
