德胜坝泵站现场测试与分析
概述: 采用LMS SCADAS III/ Test . Lab 系统和对红外热像仪等先进设备对德胜坝泵站进行现场测试, 对测试成果进行分析. 表明德胜坝泵站机组装置效率低下, 闸门无法正常关闭, 机组设备运行状态差, 建议对泵站机组设备进行更新改造.
关键词: 泵站; 装置效率; 启闭机; 闸门
Abstract :A on-spot test on Desheng Pumping Station by LMS SCADAS III/ Test Lab Systemand infrared radiationthermometer is made and the data are analyzed that the device efficiencyin Desheng pumping Stationis too lowfor the gate to work , resultingin bad working
condition of the unit . The renovation of the pumping unit is badly in need .
