APB协议UVM验证环境的搭建流程
APB协议UVM验证环境的搭建
一、编译文件
只需编译这两个文件即可
UVM
apb_pkg.sv
里面包含了"apb.svh",即编译apb_pkg.sv这个文件的同时,也会编译所需要的所有的头文件。
`ifndef APB_PKG_SV
`define APB_PKG_SV
package apb_pkg;
import uvm_pkg::*;
`include "uvm_macros.svh"
`include "apb.svh"
endpackage : apb_pkg
`endif //  `ifndef APB_PKG_SV
apb.svh
`ifndef APB_SVH
`define APB_SVH
`include "apb_transfer.sv"
`include "apb_config.sv"
//master所有的头文件
`include "apb_master_driver.svh"
`include "apb_master_monitor.svh"
`include "apb_master_sequencer.svh"
`include "apb_master_agent.svh"
//slave所有的头文件
`include "apb_slave_driver.svh"
`include "apb_slave_monitor.svh"
`include "apb_slave_sequencer.svh"
`include "apb_slave_agent.svh"
//master头文件里面具体的实现方法
`include "apb_master_driver.sv"
`include "apb_master_monitor.sv"
`include "apb_master_sequencer.sv"
`include "apb_master_agent.sv"
`include "apb_master_seq_lib.sv"
//slave头文件里面具体的实现方法
`include "apb_slave_driver.sv"
`include "apb_slave_monitor.sv"
`include "apb_slave_sequencer.sv"
`include "apb_slave_agent.sv"
`include "apb_slave_seq_lib.sv"
`endif //  `ifndef APB_SVH
再来编译apb_tb.sv文件
编译的同时,也会编译"apb_tests.svh"、"apb_if.sv"这两个文件。例化协议接口,配置顶层环境的master和slave,默认执行“apb_single_transaction_test”这个测试用例。
`timescale 1ps/1ps
import uvm_pkg::*;
`include "apb_tests.svh"
`include "apb_if.sv"
module apb_tb;
  bit clk, rstn;
  initial begin
    fork
      begin
        forever #5ns clk = !clk;
      end
      begin
        #100ns;
        rstn <= 1'b1;
        #100ns;
        rstn <= 1'b0;
        #100ns;
        rstn <= 1'b1;
      end
    join_none
  end
  apb_if intf(clk, rstn);
  initial begin
    uvm_config_db#(virtual apb_if)::set(uvm_root::get(), "uvm_test_top.env.mst", "vif", intf);
    uvm_config_db#(virtual apb_if)::set(uvm_root::get(), "uvm_test_top.env.slv", "vif", intf);
    run_test("apb_single_transaction_test");
  end
endmodule
apb_tests.svh
`ifndef APB_TESTS_SV
`define APB_TESTS_SV
import apb_pkg::*;
class apb_env extends uvm_env;
  apb_master_agent mst;
  apb_slave_agent slv;
  `uvm_component_utils(apb_env)
  function new(string name, uvm_component parent);
    super.new(name, parent);
  endfunction
  function void build_phase(uvm_phase phase);
    super.build_phase(phase);
    mst = apb_master_agent::create("mst", this);
    slv = apb_slave_agent::create("slv", this);
  endfunction
endclass
class apb_base_test extends uvm_test;
  apb_env env;
  `uvm_component_utils(apb_base_test)
  endfunction
    env = apb_env::create("env", this);
  endfunction
endclass
class apb_base_test_sequence extends uvm_sequence #(apb_transfer);
  bit[31:0] mem[bit[31:0]];  //关联数组mem,用来master和slave之间的数据比对,test和slave中都有一个mem
  `uvm_object_utils(apb_base_test_sequence)
  function new(string name="");
    super.new(name);
  endfunction : new
  function bit check_mem_data(bit[31:0] addr, bit[31:0] data);
    if(mem.exists(addr)) begin
      if(data != mem[addr]) begin
        `uvm_error("CMPDATA", $sformatf("addr 32'h%8x, READ DATA expected 32'h%8x != actual 32'h%8x", addr, mem[addr], data))
        return 0;
      end
      else begin
        `uvm_info("CMPDATA", $sformatf("addr 32'h%8x, READ DATA 32'h%8x comparing success!", addr, data), UVM_LOW)
        return 1;
      end
    end
    else begin
      if(data != 0) begin
        `uvm_error("CMPDATA", $sformatf("addr 32'h%8x, READ DATA expected 32'h00000000 != actual 32'h%8x", addr, data))
        return 0;
      end
      else begin
        return 1;
      end
    end
  endfunction: check_mem_data
  task wait_reset_release();
    @(negedge apb_tb.rstn);
    @(posedge apb_tb.rstn);
  endtask
  task wait_cycles(int n);
    repeat(n) @(posedge apb_tb.clk);
  endtask
  function bit[31:0] get_rand_addr();
    bit[31:0] addr;
    void'(std::randomize(addr) with {addr[31:12] == 0; addr[1:0] == 0;});
    return addr;
  endfunction
endclass
class apb_single_transaction_sequence extends apb_base_test_sequence;
  apb_master_single_write_sequence single_write_seq;
  apb_master_single_read_sequence single_read_seq;
  apb_master_write_read_sequence write_read_seq;
  rand int test_num = 100;
  constraint cstr{
    soft test_num == 100;
  `uvm_object_utils(apb_single_transaction_sequence)
    super.new(name);
  endfunction : new
  task body();
    bit[31:0] addr;
    this.wait_reset_release();
    this.wait_cycles(10);
    // TEST continous write transaction
    `uvm_info(get_type_name(), "TEST continous write transaction...", UVM_LOW)
    repeat(test_num) begin
      addr = this.get_rand_addr();
      `uvm_do_with(single_write_seq, {addr == local::addr; data == local::addr;})
      mem[addr] = addr;
    end
    // TEST continous read transaction
    `uvm_info(get_type_name(), "TEST continous read transaction...", UVM_LOW)
      `uvm_do_with(single_read_seq, {addr == local::addr;})
      void'(this.check_mem_data(addr, single_read_seq.data));
    end
    // TEST read transaction after write transaction
    `uvm_info(get_type_name(), "TEST read transaction after write transaction...", UVM_LOW)
      mem[addr] = addr;
    end
    // TEST read transaction immediately after write transaction
    `uvm_info(get_type_name(), "TEST read transaction immediately after write transaction", UVM_LOW)
      `uvm_do_with(write_read_seq, {addr == local::addr; data == local::addr;})
      mem[addr] = addr;
      void'(this.check_mem_data(addr, write_read_seq.data));
    end
  endtask
endclass: apb_single_transaction_sequence
class apb_single_transaction_test extends apb_base_test;
  `uvm_component_utils(apb_single_transaction_test)
  endfunction
  task run_phase(uvm_phase phase);
    apb_single_transaction_sequence seq = new();
    phase.raise_objection(this);
    super.run_phase(phase);
    seq.start(env.mst.sequencer);
    phase.drop_objection(this);
  endtask
endclass: apb_single_transaction_test
class apb_burst_transaction_sequence extends apb_base_test_sequence;
  apb_master_burst_write_sequence burst_write_seq;
  apb_master_burst_read_sequence burst_read_seq;
  constraint cstr{
  `uvm_object_utils(apb_burst_transaction_sequence)
    super.new(name);
  endfunction : new
  task body();
    bit[31:0] addr;
      `uvm_do_with(burst_write_seq, {addr == local::addr;})
      foreach(burst_write_seq.data[i]) begin
        mem[addr+(i<<2)] = burst_write_seq.data[i];
      end
      `uvm_do_with(burst_read_seq, {addr == local::addr; data.size() == burst_write_seq.data.size();})
      foreach(burst_read_seq.data[i]) begin
        void'(this.check_mem_data(addr+(i<<2), burst_write_seq.data[i]));
      end
    end
  endtask
endclass: apb_burst_transaction_sequence
class apb_burst_transaction_test extends apb_base_test;
  `uvm_component_utils(apb_burst_transaction_test)
  endfunction
    apb_burst_transaction_sequence seq = new();
  endtask
endclass: apb_burst_transaction_test
`endif // APB_TESTS_SV
apb_if.sv
`ifndef APB_IF_SV
`define APB_IF_SV
interface apb_if (input clk, input rstn);
  logic [31:0] paddr;
  logic        pwrite;
  logic        psel;
  logic        penable;
  logic [31:0] pwdata;
  logic [31:0] prdata;
  // Control flags
  bit                has_checks = 1;
  bit                has_coverage = 1;
  // Actual Signals
  // USER: Add interface signals
  clocking cb_mst @(posedge clk);
    // USER: Add clocking block detail
    default input #1ps output #1ps;
    output paddr, pwrite, psel, penable, pwdata;
    input prdata;
  endclocking : cb_mst
  clocking cb_slv @(posedge clk);
    input paddr, pwrite, psel, penable, pwdata;
    output prdata;
  endclocking : cb_slv
  clocking cb_mon @(posedge clk);
    input paddr, pwrite, psel, penable, pwdata, prdata;
  endclocking : cb_mon
  // Coverage and assertions to be implemented here.
  // USER: Add assertions/coverage here
  // APB command covergroup
  covergroup cg_apb_command @(posedge clk iff rstn);
    pwrite: coverpoint pwrite{
      type_option.weight = 0;
      bins write = {1};
      bins read  = {0};
    psel : coverpoint psel{
      bins sel   = {1};
      bins unsel = {0};
    cmd  : cross pwrite, psel{
      bins cmd_write = binsof(psel.sel) && binsof(pwrite.write);
      bins cmd_read  = binsof(psel.sel) && binsof(pwrite.read);
      bins cmd_idle  = binsof(psel.unsel);
  endgroup
  // APB transaction timing group
  covergroup cg_apb_trans_timing_group @(posedge clk iff rstn);
    psel: coverpoint psel{
      bins single   = (0 => 1 => 1  => 0);
      bins burst_2  = (0 => 1 [*4]  => 0);
      bins burst_4  = (0 => 1 [*8]  => 0);
      bins burst_8  = (0 => 1 [*16] => 0);
      bins burst_16 = (0 => 1 [*32] => 0);
      bins burst_32 = (0 => 1 [*64] => 0);
    penable: coverpoint penable {
      bins single = (0 => 1 => 0 [*2:10] => 1);
      bins burst  = (0 => 1 => 0         => 1);
  endgroup
  // APB write & read order group
  covergroup cg_apb_write_read_order_group @(posedge clk iff (rstn && penable));
    write_read_order: coverpoint pwrite{
      bins write_write = (1 => 1);
      bins write_read  = (1 => 0);
      bins read_write  = (0 => 1);
      bins read_read   = (0 => 0);
  endgroup
  initial begin
    automatic cg_apb_command cg0 = new();
    automatic cg_apb_trans_timing_group cg1 = new();
    automatic cg_apb_write_read_order_group cg2 = new();
  end
endinterface : apb_if
`endif // APB_IF_SV
二、apb_tests.sv代码分析
apb_base_test_sequence类
check_mem_data()方法原理结构框图:
关联数组mem,用来master和slave之间的数据比对,test和slave中都有一个mem,master通过接口发送数据给slave,slave中的mem和test中的mem都会存储这个数据,等从slave读回数据时,就可以和test中mem里面的数据进行比较。
UVM
apb_single_transaction_sequence类
随机化addr,测试连续写操作
      mem[addr] = addr;
    end
随机化addr,测试连续读操作,并比较数据是否一致
    end
随机化addr,先进行写操作,再进行读操作,并比较读取的数据是否一致
      mem[addr] = addr;
    end
随机化addr,写完立即读,中间没有idle空闲,并检查读取数据是否一致
      mem[addr] = addr;
    end
例化并挂载
  endfunction
  endtask
apb_burst_transaction_sequence类
先全部写操作完毕,在完全读出来,地址是连续增长的
      end
      end
    end
例化并挂载
  endfunction
  endtask
三、apb_master_agent.sv代码分析
agent包括三个组件driver、sequencer、monitor,以及config和interface。
例化monitor,根据配置决定是否例化driver和sequencer
function void apb_master_agent::build();
  super.build();
  // get config
  if( !uvm_config_db#(apb_config)::get(this,"","cfg", cfg)) begin
    `uvm_warning("GETCFG","cannot get config object from config DB")
     cfg = apb_config::create("cfg");
  end
  // get virtual interface
  if( !uvm_config_db#(virtual apb_if)::get(this,"","vif", vif)) begin
    `uvm_fatal("GETVIF","cannot get vif handle from config DB")
  end
  monitor = apb_master_monitor::create("monitor",this);
  monitor.cfg = cfg;
  if(cfg.is_active == UVM_ACTIVE) begin
    sequencer = apb_master_sequencer::create("sequencer",this);
    sequencer.cfg = cfg;
    driver = apb_master_driver::create("driver",this);
    driver.cfg = cfg;
  end
endfunction : build
根据配置决定是否连接driver和sequencer
function void apb_master_agent::connect();
  assign_vi(vif);
  if(is_active == UVM_ACTIVE) begin
    driver.seq_item_port.connect(sequencer.seq_item_export);
  end
endfunction : connect
根据配置决定是否vif和driver、sequencer之间的连接
function void apb_master_agent::assign_vi(virtual apb_if vif);
   monitor.vif = vif;
   if (is_active == UVM_ACTIVE) begin
      sequencer.vif = vif;
      driver.vif = vif;
    end
endfunction : assign_vi
四、apb_master_driver.sv代码分析
并行触发get_and_drive()、reset_listener()
task apb_master_driver::run();
   fork
     get_and_drive();
     reset_listener();
   join_none
endtask : run
捕捉到复位信号以后,所以信号清零
task apb_master_driver::reset_listener();
  `uvm_info(get_type_name(), "reset_listener ...", UVM_HIGH)
  fork
    forever begin
      @(negedge vif.rstn); // ASYNC reset
      vif.paddr <= 0;
      vif.pwrite <= 0;
      vif.psel <= 0;
      vif.penable <= 0;
      vif.pwdata <= 0;
    end
  join_none
endtask
sequence和sequencer需要握手,获取transaction以后调用driver_transfer()发送。发送成功以后克隆request生成新的response,作为响应发送回去。
task apb_master_driver::get_and_drive();
  forever begin
    seq_item_port.get_next_item(req);
    `uvm_info(get_type_name(), "sequencer got next item", UVM_HIGH)
    drive_transfer(req);
    void'($cast(rsp, req.clone()));
    rsp.set_sequence_id(req.get_sequence_id());
    seq_item_port.item_done(rsp);
    `uvm_info(get_type_name(), "sequencer item_done_triggered", UVM_HIGH)
  end
endtask : get_and_drive
task apb_master_driver::drive_transfer (apb_transfer t);
  `uvm_info(get_type_name(), "drive_transfer", UVM_HIGH)
  case(t.trans_kind)
    IDLE    : this.do_idle();
    WRITE   : this.do_write(t);
    READ    : this.do_read(t);
    default : `uvm_error("ERRTYPE", "unrecognized transaction type")
  endcase
endtask : drive_transfer
根据trans_kind判断操作命令,分别调用相对应的方法。
task apb_master_driver::do_write(apb_transfer t);
  `uvm_info(get_type_name(), "do_write ...", UVM_HIGH)
  //写操作一共分为两个周期,根据协议第一个周期setup准备阶段需要如下操作
  @(vif.cb_mst);
  vif.cb_mst.paddr <= t.addr;
  vif.cb_mst.pwrite <= 1;
  vif.cb_mst.psel <= 1;
  vif.cb_mst.penable <= 0;
  vif.cb_mst.pwdata <= t.data;
  //第二个阶段拉高penable信号,发送数据
  @(vif.cb_mst);
  vif.cb_mst.penable <= 1;
  repeat(t.idle_cycles) this.do_idle();  //取决于transaction里面的idle
endtask: do_write
task apb_master_driver::do_read(apb_transfer t);
  //第一个阶段
  @(vif.cb_mst);
  vif.cb_mst.pwrite <= 0;
  //第二个阶段
  @(vif.cb_mst);
  #100ps; //需要采样数据,人为添加100ps的delay,是为了避免delta-cycle
  t.data = vif.prdata;  //采样数据
endtask: do_read
task apb_master_driver::do_idle();
  `uvm_info(get_type_name(), "do_idle ...", UVM_HIGH)
  @(vif.cb_mst);
  //根据协议,paddr、pwrite可以保持不变,等待下一次的传输,这是为了省电
  //vif.cb_mst.paddr <= 0;
  //vif.cb_mst.pwrite <= 0;
  vif.cb_mst.psel <= 0;
  vif.cb_mst.pwdata <= 0;
endtask:do_idle
五、apb_master_monitor.sv代码分析
collect_transfer()方法
在时钟上升沿,同时psel=1和penabl=0的时候,判断当前情况下pwrite信号,在第二个周期进行读或者写操作。
task apb_master_monitor::collect_transfer();
  apb_transfer t;
  // Advance clock
  @(vif.cb_mon);
  if(vif.cb_slv.psel === 1'b1 && vif.cb_slv.penable === 1'b0) begin
    t = apb_transfer::create("t");
    case(vif.cb_slv.pwrite)
      1'b1    : begin
                  @(vif.cb_mon);
                  t.addr = vif.cb_mon.paddr;
                  t.data = vif.cb_mon.pwdata;
                  t.trans_kind = WRITE;
                end
      1'b0    : begin
                  @(vif.cb_mon);
                  t.data = vif.cb_mon.prdata;
                  t.trans_kind = READ;
                end
      default : `uvm_error(get_type_name(), "ERROR pwrite signal value")
    endcase
    item_collected_port.write(t);
  end
endtask: collect_transfer
六、apb_master_seq_lib.sv代码分析
apb_master_single_write_sequence类
使用宏'uvm_do_with发送数据。
class apb_master_single_write_sequence extends apb_master_base_sequence;
  rand bit [31:0]      addr;
  rand bit [31:0]      data;
  `uvm_object_utils(apb_master_single_write_sequence)
    super.new(name);
  endfunction : new
  virtual task body();
    `uvm_info(get_type_name(),"Starting sequence", UVM_HIGH)
   `uvm_do_with(req, {trans_kind == WRITE; addr == local::addr; data == local::data;})
    get_response(rsp);
    `uvm_info(get_type_name(),$psprintf("Done sequence: %s",req.convert2string()), UVM_HIGH)
  endtask: body
endclass: apb_master_single_write_sequence
apb_master_single_read_sequence类
读操作,拿到返回的rsp的数据后存储在成员变量data里。
class apb_master_single_read_sequence extends apb_master_base_sequence;
  `uvm_object_utils(apb_master_single_read_sequence)
    super.new(name);
  endfunction : new
   `uvm_do_with(req, {trans_kind == READ; addr == local::addr;})
    get_response(rsp);
    data = rsp.data;
  endtask: body
endclass: apb_master_single_read_sequence
apb_master_write_read_sequence类
写操作后进行读操作,所以idle_cycles == 0
class apb_master_write_read_sequence extends apb_master_base_sequence;
  rand int           idle_cycles;
  constraint cstr{
    idle_cycles == 0;
  `uvm_object_utils(apb_master_write_read_sequence)
    super.new(name);
  endfunction : new
                        idle_cycles == local::idle_cycles;
    get_response(rsp);
    get_response(rsp);
    data = rsp.data;
  endtask: body
endclass: apb_master_write_read_sequence
apb_master_burst_write_sequence类
连续的写操作,按照地址增长的顺序,把所有的数据写到data数组中。因为是连续写操作,所以idle_cycles == 0,即数据之间没有空闲周期。
class apb_master_burst_write_sequence extends apb_master_base_sequence;
  rand bit [31:0]      data[];
  constraint cstr{
    soft data.size() inside {4, 8, 16, 32};
    foreach(data[i]) soft data[i] == addr + (i << 2);
  `uvm_object_utils(apb_master_burst_write_sequence)
    super.new(name);
  endfunction : new
    foreach(data[i]) begin
                         addr == local::addr + (i<<2);
                         data == local::data[i];
                         idle_cycles == 0;
      get_response(rsp);
    end
    `uvm_do_with(req, {trans_kind == IDLE;})
    get_response(rsp);
  endtask: body
endclass: apb_master_burst_write_sequence
apb_master_burst_read_sequence类
连续的读操作,每次读取回来的数据,从rsp中拿出来放到data数组中。全部读取完成之后,将总线置为IDLE。
class apb_master_burst_read_sequence extends apb_master_base_sequence;
  constraint cstr{
  `uvm_object_utils(apb_master_burst_read_sequence)
    super.new(name);
  endfunction : new
                         idle_cycles == 0;
      get_response(rsp);
      data[i] = rsp.data;
    end
    get_response(rsp);
  endtask: body
endclass: apb_master_burst_read_sequence
七、apb_slave_driver.sv代码分析
slave要接收master发送过来的数据,所以要模拟一个存储功能,即关联数组mem。
  bit[31:0] mem [bit[31:0]];
run()方法
三个方法并行执行
task apb_slave_driver::run();
   fork
     get_and_drive();
     reset_listener();
     drive_response();
   join_none
endtask : run
get_and_drive()方法
task apb_slave_driver::get_and_drive();
  forever begin
  end
reset_listener()方法
等待复位信号,将prdata <= 0,同时清空mem里面的数据。
task apb_slave_driver::reset_listener();
  fork
    forever begin
      vif.prdata <= 0;
      this.mem.delete(); // reset internal memory
    end
  join_none
endtask: reset_listener
drive_response()方法
如果当前这一周期是SETUP阶段,即psel = 1 && penable = 0,进而判断是写操作还是读操作,然后调用相对应的方法。
task apb_slave_driver::drive_response();
  `uvm_info(get_type_name(), "drive_response", UVM_HIGH)
  forever begin
    @(vif.cb_slv);
        1'b1    : this.do_write();
        1'b0    : this.do_read();
      endcase
    end
    else begin
      this.do_idle();
    end
  end
endtask : drive_response
do_write()方法
如果是写操作,那么等待时钟下一拍,拿到addr和data并放到mem中。
task apb_slave_driver::do_write();
  bit[31:0] addr;
  bit[31:0] data;
  `uvm_info(get_type_name(), "do_write", UVM_HIGH)
  @(vif.cb_slv);
  addr = vif.cb_slv.paddr;
  data = vif.cb_slv.pwdata;
  mem[addr] = data;
endtask: do_write
do_read()方法
如果是读操作,等待penable=1,并且判断mem中是否写过该addr,如果有则写入data,没有则将data置为0,即还是初始化的数据。等待一个延迟后,将data驱动到总线上面。
task apb_slave_driver::do_read();
  bit[31:0] addr;
  bit[31:0] data;
  `uvm_info(get_type_name(), "do_read", UVM_HIGH)
  wait(vif.penable === 1'b1);
    data = mem[addr];
  else
    data = 0;
  #1ps;
  vif.prdata <= data;
  @(vif.cb_slv);
endtask: do_read
八、运行仿真
执行命令
run -all
验证环境结构
UVM
写操作:写入地址和写入数据相同,只有penable拉高才会写入,数据之间有一个空闲。
UVM
读操作:只有penable拉高才会读数据,没有写入过数据的地址,读出来的值为0。
UVM
先写后读:
UVM
写完立即读操作:
UVM
仿真结果:
UVM
覆盖率:
      bins write = {1};
      bins read  = {0};
      bins sel   = {1};
      bins unsel = {0};
  endgroup
  endgroup
  endgroup
UVM
审核编辑:刘清
  • 相关推荐
  • 热点推荐
  • UVM
