LT5514三阶互调的精确测量
消耗积分:0 | 格式:pdf | 大小:79.4 KB | 2012-01-10
分享资料个
Accurate measurement of the third order intercept pointfor low distortion IC products such as the LT5514 requirescertain precautions to be observed in the test setup andtesting procedure. The LT5514 linearity performance ishigh enough to push the test equipment and test set-up totheir limits. A method for accurate measurement of thirdorder intermodulation products, IM3, with standard testequipment is outlined below.It is also important to correctly interpret the LT5514specification with respect to ROUT, and the impact ofdemo-board transmission-line termination loss whenevaluating the linearity performance, as explained in theLT5514 Datasheet and in Note 1 of this document.
评论(0)
发评论
下载排行榜
