The X9241 has a variety of different instructions that provide flexibility to the designer. Additionally, the nonvolatile nature of the device allows for stored wiper positions that can be retrieved after power cycles. The following code implements all of the available X9241 instructions using a standard bi-directional bus protocol. Although the routines occupy less than 300 bytes of program memory, designers who won't need to implement all of the X9241 instructions can shorten the code by removing any unnecessary routines. However, this will necessitate the reassembly of the code.
