The ADE7760 is a high accuracy, fault tolerant, electrical energy measurement IC intended for use with 2-wire distribution systems. The part specifications surpass the accuracy require- ments as quoted in the IEC61036 standard. The only analog circuitry used on the ADE7760 is in the ADCs and reference circuit. All other signal processing (such as multi- plication and filtering) is carried out in the digital domain. This approach provides superior stability and accuracy over extreme in environmental conditions and over time. The ADE7760 incorporates a fault detection scheme similar to the ADE7751 by continuously monitoring both the phase and neutral currents. A fault is indicated when these currents differ by more than 6.25%. The ADE7760 supplies average active power information on the low frequency outputs F1 and F2. The CF logic output gives instantaneous active power information. The ADE7760 includes a power supply monitoring circuit on the VDD supply pin. Internal phase-matching circuitry ensures that the voltage and current channels are matched. An internal no-load threshold ensures that the ADE7760 does not exhibit any creep when there is no load.
