使用Nios II软件构建工具
This chapter describes the Nios® II Software Build Tools (SBT), a set of utilities and
scripts that creates and builds embedded C/C++ application projects, user library
projects, and board support packages (BSPs). The Nios II SBT supports a repeatable,
scriptable, and archivable process for creating your software product.
You can invoke the Nios II SBT through either of the following user interfaces:
■ The Eclipse™ GUI
■ The Nios II Command Shell
The purpose of this chapter is to make you familiar with the internal functionality of
the Nios II SBT, independent of the user interface employed.
