The HFA3983 is a 2.4GHz monolithic SiGe Power Amplifier designed to operate in the ISM Band. It features two low voltage single supply amplifier stages (see Block Diagram).In addition, the device includes a 2.4GHz detector which is accurate over a wide dynamic range. Therefore, an accurate ALC function can be implemented.The HFA3983 is housed in a 28 lead exposed paddle EPTSSOP package (Pinout) well suited for PCMCIA board applications.
