K1010S数据手册下载
消耗积分:0 | 格式:其它 | 大小:未知 | 2012-10-30
刘平
分享资料个
cash advance
 制 造 商:Cosmo
 封    装: SOP-4
  The information contained in this document is intended to be a general product description and is subject to change without notice. Please contact cosmo in order to obtain the latest device data sheets before using any cosmo device. cosmo does not assume any responsibility for use of any circuitry described. No circuit patent licenses are implied. This publication is the property of cosmo. No part of this publication may be reproduced or copied in any form or by any means, or transferred to any third party without the prior written consent of cosmo Electronics Corporation. The devices listed in this document are designed for general applications only in electronic equipment. No devices shall be deployed which require higher level of reliability such as: – Medical and other life support equipments. – Space application. – Telecommunication equipment ( trunk lines )。 – Nuclear power control equipment. Unless it received prior written approval from cosmo. cosmo takes no responsibility for damages arise form the improper usage of our device. Please contact cosmo for further information regarding the above notices.
评论(0)
发评论
下载排行榜
