The MAX3949 is a 3.3V, multirate, low-power laser diodedriver designed for Ethernet, Fibre Channel, and SONETtransmission systems at data rates up to 11.3Gbps.
This device is optimized to drive a differential transmitteroptical subassembly (TOSA) with a 25I flex circuit.The unique design of the output stage enables use ofunmatched TOSAs.
