MAX6618芯片规格书
消耗积分:0 | 格式:pdf | 大小:276 KB | 2013-05-16
分享资料个
The MAX1878 dual power supply contains a step-downand step-up DC-DC converter in a small 12-pin TQFNpackage for use in PDAs. The step-down DC-DC converterdelivers over 500mA to an output as low as 1.25V forlogic power. The step-up DC-DC converter delivers over15mA and an output as high as 28V for a liquid crystal display(LCD). With an input voltage from 2.0V to 5.5V theMAX1878 is intended for use in systems powered by a2-cell alkaline or 1-cell lithium-ion (Li+) battery.
评论(0)
发评论
下载排行榜
