摩擦压力机打击力的测量误差分析
消耗积分:5 | 格式:rar | 大小:125 | 2009-06-23
马占云
分享资料个
对摩擦压力机打击力测量不准确的现象进行了试验验证,并从理论上分析了摩擦压
力机打击力测量误差产生的原因,探讨了摩擦压力机滑块初速度、工件质量和刚度以及测力传感器质量和刚度对摩擦压力机打击力测量误差的影响。
[关键词]  测量;打击力;误差;传感器
Abstract :  The phenomenon of the unaccurate measuring blow force in the screw press is proved in this paper. The cause of measured errors is analyzed theoretically. And the influence on measured errors is re2 searched which is caused by the initial speed of the slipper , the mass , stiffness of the force transducer and the workpiece in screw press.
Keywords :  blow force ; measurement ; error ; transducer ; dynamics
评论(0)
发评论
下载排行榜
