超再生接收机原理,国外专利(该为部分缺失资料请下载观看完整版)
ABSTRACT US 2002/0168957 A1 Nov. 14, 2002 A superregenerative oscillator RF receiver having a differ , ential output that has the advantage of providing an Int. Cl- improved Operating range and increased receiver Sensitivity (52) US‘ Cl-“ 455/336245125; 4:55; Without affecting receiver cost or current requirements. The _ ~ ; present invention comprises a receiver that has a super (58) Fleld 0f Search 455/334, 336, regenerative Oscillator from which the demodulated Output 455/337, 338, 343-1, 205, 214, 215 is taken in differential form. This is achieved by generating _ collector and emitter output signals, loW pass ?ltering both (56) References Clted signals, and then combining them in a difference ampli?er. U.S. PATENT DOCUMENTS The resulting Waveform contains approximately tWice the signal content than Would be yielded from a singled-ended 3,746,999 A * 7/1973 Free/n‘455/336 circuit. The preferred embodiment of present invention can 378057184 A 4/1974 ‘7151011: In ct a1~ also achieve quench noise cancellation With proper layout 3352110 A 12/1974 Grebene and the use of a common mode loW pass ?lter followed by 3,869,679 A 3/1975 Grebene a difference am li?er
