嵌入式以太网石油管道监测系统的设计
消耗积分:3 | 格式:rar | 大小:179 | 2009-08-06
鼠爱米
分享资料个
本文根据原油管道泄漏检测的实际要求,设计了一个基于Ethernet 的远程数据采集检
测系统。该系统将8 位MCU C8051F020 与以太网芯片连接,在MCU 上嵌入精简的TCP/IP
协议栈uIP 及实时操作系统uC/OS-II。在执行数据采集任务时,MCU 对现场采集的数据进行处理,并驱动以太网芯片将数据发送到远程在线监测系统。
关键词:MCU C8051F020,Ethernet ,监测
Abstract:Aiming at the practical requisition in oil pipeline's leakage detection, a remote data
acquisition system based on the Embedded Ethernet technology is designed in this dissertation. The system achieves eight bit MCU C8051F020 connection with Ethernet chip,embedded tidy TCP/IP protocol stack uIP and Real Time Opetarion System uC/OS-II. While it carries out data acquisition, MCU disposes the data and makes Ethernet chip transmission the data to remote inspection system.
Key word: MCU C8051F020,Ethernet , inspection
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
