OP777/OP727/OP747,pdf datashee
消耗积分:5 | 格式:rar | 大小:194 | 2009-08-28
分享资料个
The OP777 , OP727 , and OP747 are precision single , dual,and quad rail-to-rail output single- supply amplifiers featuringmicropower operation and rail-to-rail output ranges. Theseamplifier s provide improved performance over the industry -standardOP07 with ±15 V supplies , and offer the further advantage of truesingle -supply operation down to 2.7 V , andsmallerpackageoptions than any other high-voltage precision bipolar amplifier.Outputs are stable with capacitive loads of over 500 pF. Supplycurrent is less than 300 μA per amplifier at 5 V. 500 Ω series resistorsprotect the inputs, allowing input signal levels several volts above
the positive supply without phase reversal.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
