A701/2 are adjustable constant current drivers for LED applications. Six regulated current ports are designed to provide uniform and pure DC constant current sinks for driving LEDs within a large range VF variations. A701/2 provide users 6-channel constant current ports to match LEDs with equal current. Users may adjust the output current from 5mA to 40mA through an external resistor, RSET, which gives user flexibility in controlling the light intensity of LEDs. It also could precisely adjust LED brightness from 0% to 100% via output enable pin (OE) with Pulse Width Modulation signal. The thermal protection function protects IC from over temperature (150°C). Also, the thermal pad enhances the package power dissipation.
