ADE7758 Energy metering IC
消耗积分:5 | 格式:rar | 大小:433 | 2009-09-13
goodmbby
分享资料个
ANALOG INPUTS (P4, P5, P6, P7, P8 AND P11)
Voltage and current signals are connected at the screw
terminals P4-P6 and P7-P8 and P11 respectively. All analog
input signals are filtered using the on-board anti-alias filters
before being presented to the analog inputs of the ADE7758.
The default component values which are shipped with the
evaluation board are the recommended values to be used with
the ADE7758. The user can easily change these components,
however this is not recommended unless the user is familiar
with sigma-delta converters and also the criteria used for
selecting the component values for the analog input filters -See ADE7758 datasheet.
评论(0)
发评论
下载排行榜
