AD5231,pdf datasheet (1024-Pos
消耗积分:5 | 格式:rar | 大小:519 | 2009-09-22
张杰
分享资料个
The AD5231 is a nonvolatile memory1, digitally controlled potentiometer2 with 1024-step resolution. The device performs the same electronic adjustment function as a mechanical potentiometer with enhanced resolution, solid state reliability, and remote controllability. The AD5231 has versatile programming that uses a standard 3-wire serial interface for 16 modes of operation and adjustment, including scratchpad programming, memory storing and restoring, increment/decrement, ±6 dB/step log taper adjustment, wiper setting readback, and extra EEMEM for user-defined information, such as memory data for other components, look-up table, or system identification information.
评论(0)
发评论
下载排行榜
