ADN2530,pdf datasheet (Differe
消耗积分:3 | 格式:rar | 大小:551 | 2009-09-23
分享资料个
The ADN2530 laser diode driver is designed for direct modula-tion of packaged VCSELs with a differential resistance ranging from 35 Ω to 140 Ω. The active back-termination technique provides excellent matching with the output transmission lines while reducing the power dissipation in the output stage. The back-termination in the ADN2530 absorbs signal reflections from the TOSA end of the output transmission lines, enabling excellent optical eye quality to be achieved even when the TOSA end of the output transmission lines is significantly misterminated. The small package provides the optimum solution for compact modules where laser diodes are packaged in low pin count optical subassemblies.
评论(0)
发评论
下载排行榜
