LM34914,pdf datasheet (Ultra S
消耗积分:2 | 格式:rar | 大小:554 | 2009-09-29
分享资料个
The LM34914 Step-Down Switching Regulator features all
the functions needed to implement a low cost, efficient, buck
bias regulator capable of supplying at least 1.25A to the load.
To reduce excessive switch current due to the possibility of a
saturating inductor the valley current limit threshold changes
with input and output voltages, and the on-time is reduced
when current limit is detected. This buck regulator contains a
44V N-Channel Buck Switch, and is available in the thermally
enhanced 3 mm x 3 mm LLP-10 package. The feedback regulation
scheme requires no loop compensation, results in fast
load transient response, and simplifies circuit implementation.
The operating frequency remains constant with line and load
variations due to the inverse relationship between the input
voltage and the on-time. The valley current limit results in a
smooth transition from constant voltage to constant current
mode when current limit is detected, reducing the frequency
and output voltage, without the use of foldback. Additional
features include: VCC under-voltage lock-out, thermal shutdown,
gate drive under-voltage lock-out, and maximum duty
cycle limit.
评论(0)
发评论
下载排行榜
