Using a SAR Analog-to-Digital
消耗积分:3 | 格式:rar | 大小:344 | 2009-10-01
王树林
分享资料个
Using a SAR Analog-to-Digital Converter for Current Measurement in Motor Control Applications:With careful analysis, a designer can get good performance from what may, at first, look like incompatible components in a motor control system. One might assume that for a ±5V output signal from the current sensors, an Analog-to-Digital (A/D) converter using dual, high-voltage supplies (±12V)might be required, when in fact, new, less-expensive converters may work equally well.
评论(0)
发评论
下载排行榜
