RealView Microcontroller Development Kit - Version 3.20
[Device Support]
Added: RTX support for TMS470 in folder ..\ARM\Boards\TI\TMS470R1B1M\RTX_Blinky.
Added: example projects for NXP LPC2919 in folder ..\ARM\Boards\Keil\MCB2900.
Added: support for STMicroelectronics STA2051.
Added: support for AustriaMicroSystems AS3525 in folder ..\ARM\Boards\AMS\AS3525.
Added: support for NXP (Sharp) LH79524 in folder ..\ARM\Boards\NXP\LH79524.
Added: support for Winbond W90P710 in folder ..\ARM\Boards\Winbond\W90P710.
Added: RTX Traffic example for STR9 devices and corrected a problem with the interrupt controlled UART simulation of STR9.
Corrected: for Altera Cortex-M1 driver the option Use Reset at Startup was not stored.
Corrected: RT-Agent configuration AT91SAM7X with interrupts in folder ..\ARM\RT Agent\RTX\AT91SAM7X-EK\Blinky.
Corrected: Timer3 and Timer4 of LPC2101/2/3 devices was incorrectly simulated.
[RTX - Problems Solved]
Corrected: core problems for Cortex-M devices. Handling of isr_xxx function calls was incorrect and could cause task locks. Wrong handling of task switches and __svc functions could cause sporadic application crashes if additional user interrupts were enabled.
