LP3947,pdf datasheet (USB/AC A
消耗积分:5 | 格式:rar | 大小:551 | 2009-10-06
张勇
分享资料个
The LP3947 is a complete charge management system that
safely charges and maintains a Li-Ion battery from either
USB power source or AC adaptor. In USB mode, the LP3947
supports charging in low power or high power mode. Alternatively,
the LP3947 can take charge from AC adaptor. In
both USB and AC adaptor modes, charge current, battery
regulation voltage, and End of Charge (EOC) point can be
selected via I2C interface. The LP3947 can also operate on
default values that are pre-programmed in the factory. The
battery temperature is monitored continuously at the Ts pin
to safeguard against hazardous charging conditions. The
charger also has under-voltage and over-voltage protection
as well as an internal 5.6 hr timer to protect the battery. The
pass transistor and charge current sensing resistor are all
integrated inside the LP3947.
评论(1)
发评论
rzglt 2011-05-25
0 回复 举报
哎呀,下载不了呀
管理员回复: 目前网站资源只针对注册会员开放,只需要简单注册一下会员就可以下载了
收起回复
下载排行榜
全部1条评论
