lf356-ns原文资料
消耗积分:3 | 格式:pdf | 大小:377KB | 2017-03-23
951414
分享资料个
lf356-ns
These are the first monolithic JFET input operational amplifiers to incorporate well matched, high voltage JFETs on the same chip with standard bipolar transistors (BI-FETTM Technology). These amplifiers feature low input bias and offset currents/low offset voltage and offset voltage drift, coupled with offset adjust which does not degrade drift or commonmode rejection. The devices are also designed for high slew rate, wide bandwidth, extremely fast settling time, low voltage and current noise and a low 1/f noise corner.
评论(0)
发评论
下载排行榜
