DSP程序员gu6701 E指南
消耗积分:0 | 格式:rar | 大小:0.09 MB | 2017-03-30
分享资料个
  DSP程序员(gu6701−E)是一种编程单元计算机和助听器之间的接口安森美半导体DSP混合,可作为一个快速另类的喜亲。软件与DSP结合程序员组成整个编程单元。DSP程序员发送和接收数据到/从助听器程序正确的最终用户配置。
  安森美半导体DSP程序员的目的是用于高速生产环境与半导体DSP混合通信用于更快的校准和配置这些产品(见图1)。这个单位没有电隔离。DSP混合编程,该系统需要dsp编程器盒,安装一个方舟组件与USB端口可在计算机上和合适的连接电缆(见图2)。
DSP程序员gu6701 E指南
DSP程序员gu6701 E指南
  The connection between the DSP Programmer and the PC is a USB specific cable supplied by ON Semiconductor. The connection between the DSP Programmer and the hearing aid is a cable identical to the one used in HiPro applications. These connections are located on the front panel with a pin configuration as shown in Figure 3. The front panel also provides power, as well as left and right communication LEDs. Software and drivers for the DSP Programmer are included in the ARKbase distribution package.
评论(0)
发评论
下载排行榜
