信号链和PLC如何影响我们的生活
消耗积分:0 | 格式:pdf | 大小:0.19 MB | 2017-04-05
分享资料个
  How simple can a signal chain or process control be? Consider a common household oven and an electronic control unit (ECU) in an automobile.
  The oven‘s components are enclosed inside one container, so no long-distance communication is necessary. When the user sets the thermostat to the desired temperature, the oven maintains the internal temperature at the set point (Figure 1).
信号链和PLC如何影响我们的生活
评论(0)
发评论
下载排行榜
