减少可穿戴健康和健身设备设计时间
可穿戴健康,健康和健身市场非常快速移动,新产品几乎每周出现。低成本,低功耗微控制器和广泛的无线连接的可用性,有助于推动对便携性和个人健身显示器市场的增长带动。
对于一个设计团队来说,开发一种新的健康或健身设备通常意味着压缩功能,以前居住在一个床头设备成一个大小,便于携带,甚至可以绑在手腕上。市场的速度也带来了问题:花几个月来评估设备和开发自定义硬件来验证一个概念可能会导致新产品迟到,甚至完全错过了市场窗口。
本文将着眼于两个常见的可穿戴式医疗设备的例子,并确定其共享的传感,处理和通信功能。然后,它将介绍和显示如何开始与参考设计平台,具有这些必要的特性,并解决了许多与可穿戴设备相关的设计问题。
Figure 2: A block diagram of a typical pulse oximeter shows the light transmission, sensing, signal conditioning, control, communications, and display stages. (Image source: Maxim Integrated)
The main unit contains a microcontroller that receives and processes the analog sensor information, drives the LEDs, informs the user of the results via a display, and transmits the results via a wired or wireless link.
The clip connects to the main unit via a cable, but some oximeters contain all the electronics in a single, finger-mounted device.
Fitness monitor: A fitness monitor tracks and records physical activity to help improve physical fitness. A typical device tracks metrics such as heart rate, temperature, time, and distance. Like the pulse oximeter, it often consists of two distinct units: a sensor and a receiver or display unit (Figure 3).
