能量收集系统的电源管理提示
设计一个电源管理系统的来源,从环境中获取能量是具有挑战性的。上述人士透露,从太阳能电池的振动能量,甚至从热差异的力量,都是少量的,不可预知的变化。这就产生了一个显着的挑战,电源管理系统,必须有效地运行,并提供一个稳定的输出。节点供电的传感器和处理器的电压和功率的要求已经下降,所以使用能量收集源已变得更加实际,但仍然有不同的方式来管理这些电源子系统。
这显然是必要的,以优化系统的低平均功率的设计,但它也有必要了解的能量收集源的上限和下限。降压/升压转换器将有一个下限以下的功率级可以关闭或不启动,中断系统的操作。这也意味着上电顺序必须理解的影响时,每个设备与其他设备的功率,使功率消耗不推低于下限功率转换阶段。
然而,也有必要知道潜在的峰值功率,以避免压倒额外的储能元件,如电容器或电池。
Using hardware timers and interrupts rather than software reduces the overall power requirement, and having status indications and alerts implemented across the systems are essential so that power management choices can be made with the right information.
Isolating all the loads in the system and making them switchable gives the power manager more opportunities to avoid problems and optimize the performance. This also helps isolate any devices that are consuming too much power.
A buck/boost converter is a suitable architecture for harvesting energy from movement or vibration via a piezoelectric transducer. A protective shunt at the input allows the power manager to accommodate a variety of different piezoelectric elements, which can have short-circuit currents around 10 µA.
