能量收集物节点的功率转换选项
环境能量收集是物联网传感器节点的一种可能的电源,但需要小心管理。除非基于太阳能或热技术的收割机,例如,被设计为与常规电路兼容,DC / DC转换器需要进行优化的低电压输入。
物联网的传感器节点往往需要放置远离可靠的电源,但多年经营。虽然长寿命蓄电池提供供电这些设备的一个选项,一个日益可行的替代方法是使用环境能量收集,使用光源,如振动,温度差。
能量收集设计的关键问题是,权力的来源往往是高度可变的,以及不可预测的。对于电子功能,收获元素提供的功率需要使用一个或多个功率转换级来调节。
In most cases, the peak energy available for harvesting does not coincide with the peak demand of the system, which will entail storing excess energy within the system, using a component such as a supercapacitor, so that it is ready to be applied when needed. Typically, harvesting will allow the system to accumulate energy over a long period of time, during which most of the system itself will be asleep to cut its power demand. When the system wakes up to take readings and send recorded data over a network, it taps into this reservoir of accumulated energy.
