智能电网中的能量传感与管理
本文讨论了如何使用能量测量IC与当前传感器一起提供智能电网实现中的单和三相设计的诊断和故障检测、隔离和恢复。
智能仪表中使用的传感器并不是特别具有挑战性。检测电压和电流可以像线圈一样简单,但是从这些传感器中传递有用的、复杂的数据是一个挑战。现代智能电表需要一个广泛的数据反馈到电网,或者到一个地方聚合或中央办公室。
智能电表需要能够确定活动的能量(千瓦时),视在功率(kVA),无功电能(千乏),均方根值,并与单和多相仪表、工业仪表精度最高的电能质量,并能监测中的应用。所有这些都需要多个通道来捕获数据,而在过去,这些数据导致了大型、昂贵的计量系统。
通过集成传感器接口和测量来捕获和处理米表内的传感器数据是目前开发这种系统的挑战。
Multichannel current capture
The ADE7816 from Analog Devices is a highly accurate, multichannel metering device that is capable of measuring one voltage channel and up to six current channels. It measures line voltage and current and calculates active and reactive energy, as well as instantaneous RMS voltage and current. The device incorporates seven sigma-delta (Σ-Δ) ADCs with a high-accuracy energy measurement core. The six current input channels allow multiple loads to be measured simultaneously to capture the different measurements from a range of sensors, and determine the active, apparent, and reactive energy simultaneously at any point in time at the point of load. This data can then be fed back into the utility network to optimize the power delivery and create a safe and efficient feedback loop.
