能量收集应用中的平滑峰值功率要求
像无线传感器这样的应用程序可以显示出峰值功率要求超过瞬时能量水平。通过结合低功耗设计技术和功率节省系统设计方法,工程师可以将峰值功率需求平滑到可管理的水平。当这些技术和方法被用于超低功耗集成电路和高效的能量存储设备时,工程师们可以利用环境能源,即使是传统上被认为太耗电的无线应用。
与任何低功耗应用程序一样,设计者需要遵循低功耗设计的一般考虑,选择低功耗组件和低电压集成电路。对于环境供电的无线应用程序来说,满足峰值功率需求的挑战通常涉及额外的系统级考虑,设计的目的是更精确地匹配设计功能,以满足应用程序需求。
For example, in a wireless application, radio operations often present the largest energy drain. In fact, the power profile for wireless applications often shows communications functions dominating other power-consuming system states. For a wireless sensor system, Figure 1 shows the relative draw on power as the system passes through its different operational states, including: sensor data conversion (A and B), data processing (C), oscillator startup/stabilization and chip ready (D and E), data message prepare to send (F), PLL calibration (G), Rx to determine clear channel (H), Rx to Tx mode switch (I), Tx to send data (J), and switch to low-power modes for radio and MCU (K)。
