多结发光二极管处理直接交流电源
交流发光二极管是一种直接从交流线路电压运行的固态光源。一种典型的排列方式是用偏置电阻排列的两个多个发光二极管排列成一个偏置电阻来限制输入电流。然而,虽然这种技术简单又便宜,但它却有几个缺点,其中之一就是LED占用的空间。
一种改进是将LED模具细分成段并通过线连接将它们串联起来。这缩小了封装尺寸并提高了光密度,但是制造这样的器件是昂贵的,引线键合会对可靠性产生不利影响。
新一代的LED采用单一的模具,但有多个连接,使这种方法进一步发展。与集成驱动IC相结合,这些LED可以让设计者制造紧凑的固态照明,可以直接连接到电源交流电源。主要优点是提高光密度和小型灯具内部。
本文介绍了这些新设备,并解释了它们对寻找交流LED的工程师们的优势。
Powering LEDs from an AC supply
LEDs are tricky to power because designers must balance the forward-current (If) and forward-voltage (Vf) requirements against the junction temperature, efficacy, and luminosity. Illumination typically requires an If in the 350 mA to 5 A range, and a Vf of 2.5 to 12 V. Running at lower currents and voltages improves efficacy, lowers junction temperature, and extends longevity, while higher currents and voltages boost luminosity (see the TechZone article “High Current, High Brightness LEDs Simplify Power Supply Solutions”)。
For example, Cree’s XLamp XM-L2 LED requires a typical Vf of 2.9 V and can withstand a maximum current of 3 A. At a Vf of 2.9 V and If of 700 mA, the luminosity is 310 lm and efficacy is 153 lm/W. Figure 1 illustrates the forward current versus forward voltage characteristic for this chip.
