MR16 LED射灯MR16 LED灯驱动程序是与大多数电子兼容
本文讨论了低频交流变压器和电子变压器,电源电流为MR16灯的操作之间的差异。这也解释了为MR16卤素灯和MR16的LED灯电流的差异。这些差别是很重要的因为电流通常可以防止MR16 LED灯与大多数电子变压器的运行。本文将展示如何高亮度(HB)的LED驱动器的MR16灯优化将使LED灯可以与大多数电子变压器兼容性。然而,本文并没有深入到调光器和电子变压器组合的LED MR16灯的闪烁自由操作。
电阻性负载和电子变压器的重要性
MR16卤素灯正常工作的低压交流电源的低频交流变压器、高频电子变压器通常产生。在大多数MR16应用,由电力公司提供的高压交流转换为交流的高频电子变压器、低频磁变压器低压。高频电子变压器有一个初级绕组,直接连接到120伏交流电/ 230伏交流电。它采用高开关频率提供低电压(12伏),应用于MR16卤素灯。
A low-frequency AC transformer is bulky, heavy, and occupies a lot of space. In comparison, an electronic transformer is small and compact, designed to power a resistive load with a typical power demand exceeding 20 W. When an electronic transformer is powered by 120 VAC/230 VAC, most will not work if the resistive load on the output is set to draw less than 20 W.
Conventional halogen MR16 lamps draw more than 20 W of power from the AC source under normal operating conditions, so they operate well with electronic transformers. MR16 LED lamps, however, only need 7 W of power to provide the same light output as a 35 W MR16 halogen lamp.
