ANALOG PERIPHERALS 12-bit ADC - ±1LSB INL; Guaranteed Monotonic - Programmable Throughput up to 100ksps - 12 External Inputs; Programmable as Single-Ended or Differential - Programmable Amplifier Gain: 16, 8, 4, 2, 1, 0.5 - Data Dependent Windowed Interrupt Generator - Built-in Temperature Sensor (± 3°C) High-Voltage Differential Amplifier - 60V Common Mode Input Range - Offset Adjust from –60V to +60V - 16 Gain Settings from 0.05 to 16 8-bit ADC - Programmable Throughput up to 500ksps - 8 External Inputs; Programmable as Single-Ended or Differential - Programmable Amplifier Gain: 4, 2, 1, 0.5 Two 12-bit DACs Three Comparators Internal Voltage Reference Precision VDD Monitor/Brown-out Detector ON-CHIP JTAG DEBUG & BOUNDRY SCAN - On-Chip Debug Circuitry Facilitates Full Speed, Non-Intrusive In- System Debug (No Emulator Required!) - Provides Breakpoints, Single Stepping, Watchpoints, Stack Monitor, Program Trace Memory - Inspect/Modify Memory and Registers - Superior Performance to Emulation Systems Using ICE-Chips, Target Pods, and Sockets - IEEE1149.1 Compliant Boundary Scan HIGH SPEED 8051 μC CORE - Pipe-lined Instruction Architecture; Executes 70% of Instructions in 1 or 2 System Clocks - Up to 25MIPS Throughput with 25MHz System Clock - Expanded Interrupt Handler MEMORY - 4352 Bytes Internal Data RAM (256 + 4k) - 64k Bytes In-System Programmable FLASH Program Memory - External 64k Byte Data Memory Interface CAN Bus 2.0B - 32 Message Objects - “Mailbox” implementation only interrupts CPU when needed DIGITAL PERIPHERALS - 32 Port I/O; All are 5V tolerant - Hardware SMBusTM (I2CTM Compatible), SPITM, and Two UART Serial Ports Available Concurrently - Programmable 16-bit Counter Array with 6 Capture/Compare Modules - Five General Purpose 16-bit Counter/Timers - Dedicated Watch-Dog Timer; Bi-directional Reset CLOCK SOURCES - Internal Programmable 2% Oscillator: Up to 25MHz - External Oscillator: Crystal, RC, C, or Clock - Real-Time Clock Mode using Timer 3 or PCA SUPPLY VOLTAGE ......................... 2.7V to 3.6V - Typical Operating Current: 10mA @ 25MHz - Multiple Power Saving Sleep and Shutdown Modes 64-Pin TQFP; Temp Range –40°C to +85°C
