Having the Factory Light Itself
消耗积分:0 | 格式:rar | 大小:0.14 MB | 2017-07-07
分享资料个
  工业照明应用空间在办公室和工厂之间划分。在工厂中,应用程序需要较长的组件寿命,最小的服务和自主操作。这些特性使得工厂地板及其相关的照明解决方案成为支持本地收获能源解决方案的候选产品。
  利用太阳能和压电光源来帮助支持局部照明越来越受欢迎,因为照明功率下降到水平,使新的高效率收割机可能。实现这些系统的关键是收集和分配所收集的电力。选择正确的照明类型,驱动程序选项,以及电源存储和调节环境是成功部署这些自供电系统的主要因素。
  Types of lighting
  Industrial lighting in factories has long been characterized by high-power, high-wattage area lighting. In addition to fluorescent tube lighting and large-format circular lighting, factories have also used halogen and sodium bulbs. These are in addition to the traditional incandescent lights, available in spot, flood, and regular bulb format. The sodium bulbs are all controlled by 110 to 240 volt AC supplies which drive the ballasts and the lights with high current levels. Most of these lights have supplies in the 70 to 500 watt range and generate a great deal of heat in addition to light. They have good efficiency for their class in the 100 to 200 lumens per watt range with a moderate life of 10,000 to 20,000 hours.
评论(0)
发评论
下载排行榜
