具有信号隔离和功率隔离的锂离子电池组监控器
电路功能与效益
锂离子(Li Ion)电池堆中含有大量的单个电池,必须对其进行正确的监控,以提高电池的效率,延长电池的使用寿命。在图1中所示的行为作为主要监测电池管理控制器提供精确的测量数据的电路通道的ad7280a设备(BMC)。的ad7280a内部包含±3 ppm的参考,让一个±1.6 mV的电池电压测量精度。ADC分辨率为12位,允许在7微米内转换多达48个单元。
的ad7280a,驻留在电池管理系统(BMS),高压侧界面菊花链,允许最多八ad7280as被堆放在一起,允许48的锂离子电池电压进行监测。堆栈中的相邻ad7280as可以直接沟通,向上和向下的数据传递不需要堆栈分离。在堆栈的底部ad7280a主设备采用SPI接口与BMC沟通,而只有在这一点上,高压电隔离是为了保护系统低压侧。的数字隔离器,隔离器ADuM1201 adum5401集成DC/DC变换器结合在一个紧凑的和成本有效的解决方案,提供所需的六通道隔离。
Circuit description
The AD7280A daisy chain obtains its power from the battery cells it monitors. The ADuM5401 includes an integrated DC-to-DC converter which is used to power the high voltage side of the ADuM1201, provide the VDRIVE supply to the AD7280A SPI interface, and provide the power-down (PD) signal to the AD7280A daisy chain circuit. If the +5 V supply is pulled low on the low voltage side of the BMS, the isolators and the chain of AD7280A’s will power down. Likewise, if the PD signal from the BMC is taken low, the low voltage supply to the ADuM5401 routed through the ADG849 switch is driven low and also provides a hardware power down of the isolators and the chain of AD7280A devices.
