另一个LED市场:LED驱动程序
消费者终端产品的快速变化使LED驱动市场充满活力。最近的趋势和技术研究突出了市场的走向。
有很多聊天现在的LED,LED背光,LED照明,甚至金属有机气相外延(MOCVD)设备,但并没有太多的关于LED驱动器和驱动IC市场。驱动程序的设计决定了LED产品的性能,并将是关键,使价格和性能要求的一般LED照明。事实上,驱动电子和LED的联姻就是产品。然而,LED驱动市场是一个积极的,但主要是无形的,至少对大多数行业。
原因很多。一位供应商告诉我们,向客户解释LED驱动程序需要一个“深潜”,很少有耐心或专业知识坐下来。也有一种误解,驱动技术是静态的规范。现实的情况是完全不同的;每一个应用程序需要独特的驱动设计,与供应商保持创新与最终产品的变化,如从键盘到触摸屏的迁移,LED相机闪光灯,和各种风味的LED TV背光。甚至用于驱动集成电路的过程也在不断发展。
Also, the influence of drivers is deep, but subtle. For example, using the simplest driver design may require tight binning of LEDs that drives up the cost of the LEDs. Using a more refined driver design can relax the requirements on binning, saving money. In another example, LED drivers are rated for the maximum output power they can deliver, and the efficiency at full load; for example, 90 percent at 35 watts. However, the power loss can be substantially more if the circuit is not fully loaded. Such nuances in design are familiar to many analog engineers, but many lighting products nonetheless use inferior designs because of inexperience, or to save cost.
