亚GHz无线部署的主要优先事项
消耗积分:0 | 格式:rar | 大小:0.28 MB | 2017-08-03
分享资料个
  亚GHz无线部署的主要优先事项
  建立一个先进的无线系统,大多数开发者会选择两工业,科学和医疗(ISM)频段的options-2.4 GHz或子千兆赫的频率。将一个或另一个与系统的最高优先级配对,将提供无线性能和经济性的最佳结合。这些优先事项可以包括:范围、功耗、数据速率、天线尺寸、互操作性(标准)和全球部署。然而,对于低数据速率应用,如家庭安全/自动化和智能计量,亚千兆赫无线系统提供了几个优点,包括更长的范围、降低的功耗和较低的部署和运营成本。
  的sub-GHz无线电
  亚千兆赫无线电可以提供相对简单的无线解决方案,可以不间断地使用电池供电,长达20年。显著的优势超过2.4 GHz的无线电包括:
  亚GHz无线部署的主要优先事项
  Range -- The narrowband operation of a sub-GHz radio enables transmission ranges of a kilometer or more. This allows sub-GHz nodes to communicate directly with a distant hub without hopping from node to node, as is often required using a much shorter-range 2.4 GHz solution. There are three primary reasons for sub-GHz superior range performance over 2.4 GHz applications:
  As radio waves pass through walls and other obstacles, the signal weakens. Attenuation rates increase at higher frequencies, therefore the 2.4 GHz signal weakens faster than a sub-GHz signal.
  2.4 GHz radio waves also fade more quickly than sub-GHz waves as they reflect off dense surfaces. In highly congested environments, the 2.4 GHz transmission can weaken rapidly, which adversely affects signal quality.
  Even though radio waves travel in a straight line, they do bend when they hit a solid edge (like the corner of a building)。 As frequencies decrease, the angle of diffraction increases, allowing sub-GHz signals to bend farther around an obstacle, reducing the blocking effect.
评论(0)
发评论
下载排行榜
