无线医疗系统
在医院和家中,无线技术是革命性的医疗保健作为新的应用出现的所有时间。
无线连接正在席卷医疗行业,给病人更多的流动性,给医生提供更实时、更真实的信息,让病人四处走动,而不是把他们困在床上,包裹在电线的“鸟巢”里。医疗行业没有单一的无线标准。相反,这个产业似乎拥抱所有的无线标准®–蓝牙,ZigBee®,Wi-Fi®(IEEE 802.11a,b,g,n)、射频识别、近场通信(NFC),和更多。本文概述了各种医疗监控系统的无线系统实现的各种方法。
在医院,医生的办公室,在家里,医疗产品,将无线,给予患者更多的流动性,给医生的访问记录在任何地方都可以,让护士、医生和其他医疗服务提供者收集在巡查记录数据(见图1)。为了连接各种数据收集工具、数据捕获工具和诊断系统,设计者有多种无线连接选项。每个选项都有一组不同的数据传输速度、功耗水平和工作频率。根据应用场景,每个无线标准-蓝牙,ZigBee,Wi-Fi,NFC,RFID,或简单的计划,如振幅键控(ASK)或开关键控(ook马)-有其在医疗和健身基础设施的地方。
Figure 1: Wireless communications have made many inroads into medical systems. (Source: Microchip Technology. Used with Permission)。
Which standard to choose?
For low-cost applications such as “smart” running shoes, simple heart-rate monitors, and other equipment which only require a transmission distance of several yards for the sensor to send a signal to a nearby receiver, low-power schemes like ASK, OOK, or the new low-power Bluetooth or ZigBee schemes would be a good fit.
However, in a hospital environment, Wi-Fi can be used to keep the doctors connected via date-entry/retrieval tablets or other hand-held devices that can be kept in charging cradles when not in use.
