开发套件减少时间能量收集应用设计
“零功率”设备利用来自周围能源的能源,对电力管理提出了重大挑战。能够有效地获取能量的电路必须在不断消耗能量的同时响应不断变化的电力需求。工程师可以通过使用开发工具包快速获得设计能源收集应用程序并加速新产品开发的经验。能量采集开发包提供完整的零功率示例应用程序的设计和可从供应商如Cymbet、EnOcean、芯片,Silicon Labs、德克萨斯文书。
能量收集的设计需要仔细注意待机和峰值功率的需求因为环境来源,他们依靠提供单纯的瞬时功率瓦(见图1)。待机模式下的有效设计必须为应用提供足够的功率,而且通常还必须向低自放电的功率存储设备充电,如薄膜电池、超级电容器或两者。
在高需求期间,存储设备必须提供足够的容量来处理峰值负载,并且仍有足够的能量安全地返回到待机模式。峰值功率的要求,可以在一些能量收集应用是巨大的。例如,在设备必须同时采样传感器和传输数据的期间,零功率无线传感器通常需要超过10毫安,远高于直接从环境源获得的功率电平。
Figure 1: Energy harvesting design is primarily an exercise in energy management and requires efficient circuitry capable of handling energy input, power output and energy storage using thin-film devices or supercapacitors. (Source: SiLabs.)
Engineers are familiar with the challenges of designing an effective power budget. However, energy harvesting creates new questions about how to balance energy availability with power utilization. In particular, engineers need to focus on system initialization demands, especially during cold boot, when an energy-harvesting system starts or restarts with no stored power. This situation can occur because the device was turned off or because its primary energy source was unavailable for a prolonged period. For example, light-powered wireless sensors must cold boot after being in the dark for extended periods.
