创新的连接
Digi-Key的气象中心利用最新的无线技术来监测广泛变风条件。
明尼苏达北部的天气令人印象深刻的各种经验。空气的温度范围从40到100°°F F和包括周分零日间高点和风寒因素低于70°F.季节带来严重的暴风雪,令人印象深刻的雷暴和龙卷风,小于8.5小时,超过16小时的阳光每一天的范围,与风速,补充这气候变量数组。这种独特的极端天气的组合,结合渴望展示的无线连接(图1),导致了Digi-Key气象中心的创建(图2)。一个天气的中心部件是一个风速仪,跟踪平均风速和几阵风。
图1:互联网连接路径。天气中心扩展到显示节点37,它配备了一个风速计测量风速。
Making the right choice
Choosing an anemometer that could withstand the harsh northern Minnesota weather without breaking the bank was a challenge. While sonic anemometers are very robust, and have undeniable ‘geek’ appeal, a glance at the Weather Center budget encouraged us to continue looking for another solution. After much consideration and comparison, the model 40R from APRS (aprsworld.com) was chosen and installed (Figure 3).
