Single In-Line terminals array suitable for P.C. board mounting Surge overload ratings to 250 amperes peak The plastic material used carries UnderwritersLaboratory flammability recognition 94V-0 High temperature soldering guaranteed 265 C/10 seconds/.375“(9.5mm) lead length at 5 lbs (2.3kg) tension
Mechanical DataCase: Molded plastic Terminals: Plated wire leads solderable per MIL-STD-202,Method 208 Mounting Position: Any Weight: 0.3 ounce, 8 grams (approx) Mounting Torque: 5 in-lb maximum
