道路车辆环境的条件和测试电气和电子设备
消耗积分:0 | 格式:pdf | 大小:743KB | 2017-09-20
jxj28jxj
分享资料个
电器及电子设备
  ISO (the International Organization for Standardization) is a worldwide federation of national standards bodies (ISO member bodies)。 The work of preparing International Standards is normally carried out through ISO technical committees. Each member body interested in a subject for which a technical committee has been established has the right to be represented on that committee. International organizations, governmental and non-governmental, in liaison with ISO, also take part in the work. ISO collaborates closely with the International Electrotechnical Commission (IEC) on all matters of electrotechnical standardization. International Standards are drafted in accordance with the rules given in the ISO/IEC Directives, Part 2. The main task of technical committees is to prepare International Standards. Draft International Standards adopted by the technical committees are circulated to the member bodies for voting. Publication as an International Standard requires approval by at least 75 % of the member bodies casting a vote. Attention is drawn to the possibility that some of the elements of this document may be the subject of patent rights. ISO shall not be held responsible for identifying any or all such patent rights. ISO 16750-1 was prepared by Technical Committee ISO/TC 22, Road vehicles, Subcommittee SC 3, Electrical and electronic equipment. This second edition cancels and replaces the first edition (ISO 16750-1:2003), which has been technically revised. ISO 16750 consists of the following parts, under the general title Road vehicles — Environmental conditions and testing for electrical and electronic equipment:
评论(0)
发评论
下载排行榜
